16hp simplicity
Old 09-05-16, 09:44 AM
G
16hp simplicity
I am having trouble with my 16hp simplicity Was running fine shut it off and when i restarted it it sounds like it is back firing through the carb and won't stay running also had to charge battery
Old 09-05-16, 09:54 AM
Received 29 Upvotes on 28 Posts
When it's cooled down, take out the plug and spin it over with your thumb over the plug hole. It sounds like a stuck valve.
Old 09-05-16, 11:53 AM
P
Received 1,764 Upvotes on 1,577 Posts
It sounds like you have multiple, unrelated problems. Battery charging is largely a separate issue from the engine not running problem.
How long did the machine sit after you turned it off before restarting? When you say it won't stay running does that mean it runs for a while and then cuts off or does it not even fire?
Old 09-05-16, 12:07 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
We need a little more info than that... Might be a kohler, but I'm guessing.
Old 09-06-16, 08:10 AM
G
To cheese the motor is a briggs
Old 09-06-16, 09:38 AM
G
16hp simplicity
Found the problem bent push rod but now where do i get one and what caused it to do that
Old 09-06-16, 09:55 AM
You can get them from a lot of small engine dealers. Stuck valve or valve lash out of adjustment.
Old 09-06-16, 10:27 AM
G
16hp simplicity
how do i free a stuck valve
Old 09-06-16, 10:35 AM
The best way is to take it out and clean the stem, then use solvent to clean the guide - lube it up and reassemble. If you don't want to disassemble you can spray the valve stem with a penetrating oil and work the valve up and down. It usually frees them up.
