IN
09-14-16, 09:52 AM
Craftsman lawn tractor problems, 16 hp B&S engine
The problem is the tractor will run for about 30 min. then it will start missing out and then die. I will let it cool, then it runs again for a short time, then starts missing out again and dies. I've changed the plug and fuel filter, air cleaner, and I cleaned gas cap hole. Also cleaned and set coil. Does any one have any suggestions on what to do now?
Thanks! dshearer
Thanks! dshearer
NC
09-14-16, 09:58 AM
Try loosening or removing the gas cap and see if the problem continues. Also, the next time it dies immediately check for spark while the engine is still hot. If it wasn't the fuel cap and you still have spark when it dies then I'd check the valve adjustment.
CT
09-15-16, 04:30 AM
A vapor lock can be created in the gas line if it is in close proximity of a heat source and cause the engine to stop because the vapor lock stops the flow of gas. The eventual cooling of the gas line allows the vapor lock to exit and the engine will run fine again until a new vapor lock is created. If you think this may be your problem, try the following. When the engine stops. immediately remove the gas line at the inlet of the carb. Use a container to catch the gas. With gas flowing out the gas line, reconnect to the carb. If the engine restarts, you have removed the vapor lock. The remedy is to reroute the gas line, keeping it away from sources of heat. Good luck.
IN
KS
09-18-16, 01:09 PM
If you would post the model # it would be easier to discern.
Vapor lock is a possibility however, not likely IMO. I would lean more towards what cheese mentioned, perhaps a fuel line deteriorated and collapsing....
Without knowing if you have a fuel pump or not, it could also be vacuum line to the fuel pump, or failing pump....
I would also not rule out a failing coil at this point.
Just needs a bigger hammer
Peace
IN
09-19-16, 06:37 AM
The model # is 283H07 type-0339-E1. This engine has no fuel pump. When it started missing out again, I undid the fuel line to the carb and let the fuel start running out , then reconnected the line and restarted the engine. It ran good for a little while, then started missing out again. I also checked the spark, it was fine.
IA
IN
10-08-16, 04:28 PM
Well guy's I put in a new coil and that is not the problem! I put new fuel lines on, cleaned the carb and it still starts running rough after a little while, but it doesn' t
die. I let it run for a few minutes and it runs alright. Then it starts all over again!
Does anyone have any other ideas? Please! Help!:
