Husqvarna mower problems
Old 09-29-16, 02:23 PM
D
My buddy pushed his mower under a bush and it broke the main bolt and the plastic mold on the carburetor. I believe he couldn't figure out how to put the linkages back together.
I searched the interweb and couldn't find the right picture showing the correct way to reassemble the carb linkage.
When I put this info in on the briggs site there are no results
serial 1201186227438
When I put this info in the Husqavarna site. 2 results show 2011 & 2013 I think its the 2011.
Product maintenance level
96145000700
Serial
020212m017327
model
HU775H
Cut width
22in
Old 09-29-16, 03:52 PM
BFHFixit's Avatar
Your engine should be 111P02-0116-F1, on the Briggs site only type in 111p02-0116. Or click on this link.
Here is a link to parts listings for the rest of your mower.
Looks like you have an auto choke which is the linkage that goes up under the front of the engine to the muffler. This linkage goes to the black plastic lever on the outside of the carb.
The other linkage should run along side of the engine back to the governor and goes into the metal lever closest to the engine.
The carb will have to be removed to hook it up, being able to lean and tilt etc. Hook up the choke linkage first, then the throttle linkage.
