TroyBilt XP 7000 generator battery start
Old 10-30-16, 07:48 PM
G
I have a TroyBilt XP 7000 generator that will not start with the battery start. It starts fine with the pull cord but when I push the battery start the starter just whirs and never tries to start the motor. It doesn't seem to be a charge issue as the starter responds, it just never catches. Any ideas what the problem might be?
Old 10-30-16, 08:17 PM
Received 1,408 Votes on 1,303 Posts
Welcome to the forums.
It appears the generator needs a starter. There is a solenoid inside of it that pushes the drive gear out to engage the flywheel. That solenoid looks to be defective.
I was not able to find the starter for that unit. TroyBilt is not particularly helpful with parts.
One good thing is that genny should be using a Briggs and Stratton engine making the starter easier to find.
Old 10-30-16, 08:34 PM
cheese's Avatar
Received 50 Votes on 45 Posts
Usually your problem is caused by either a low battery, a battery connected backwards, a stuck starter gear, or a broken starter gear. The gear is replaceable, just a few bucks. All easily remedied.
Old 10-31-16, 10:14 AM
P
Received 787 Votes on 724 Posts
When in doubt check the battery. Even a almost dead battery has enough to make the starter turn. You can take the battery to any auto parts store and have them check it.
