Husqvarna 137 Chainsaw Idle
Old 11-05-16, 11:40 AM
This thing has been getting gradually worse. When it was new the idle was lean, but at least it didn't die. Then it got worse, and worse. Today I finally had a look at the carburetor, cleaned, seems fine. The L screw is practically fully open, idle is so lean it dies.
Is there some gasket I should look at? Blown so it is getting air?
Old 11-05-16, 11:53 AM
cheese's Avatar
Check for cracked fuel lines or primer bulb. Barring that, the carburetor is the most likely culprit.
Old 11-05-16, 02:08 PM
Thanks for reply! Replaced the fuel lines and primer bulb, should have mentioned. Anything I can do with this carburetor short of replacing? I used to work on carburetors in past, but this is so small and I really do not see how I could clean it thoroughly. I used compressed air and paint thinner I happened to have handy.
Old 11-05-16, 05:29 PM
cheese's Avatar
Aerosol carburetor cleaner works to dissolve old gas varnish, paint thinner doesn't. Try some and see. Shoot it through the idle circuit well.
Old 11-06-16, 05:09 PM
You were right. I took the damn thing apart one more time, verified the idle circuit, used compressed air one more time - was too lazy to go shopping for cleaner - and it works! It responds to idle screw and it idles without lean sound. This is very first time I hear it idling like this. As I said before, it was lean when it was new. Has something to do with EPA, I guess.
