Need piston seals for Husky HHD2NK air compressor
Old 11-25-16, 05:54 PM
D
Received 3 Upvotes on 3 Posts
MY pop has one of these and would really like to fix it. Seems that the piston seals are bad. So far I haven't had a lot of luck finding this part. Is it something standard that I can get online or is it specific to this model?
Old 11-25-16, 06:07 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
It doesn't appear to be a part that is offered by itself, only as an assembly in the pump. Around $80. I wouldn't put much into it, being a very low grade chinese pump not capable of much volume at all, maybe enough to run a staple gun or pump tires up now and then. If you could get the piston somewhere, it might be worth it but I don't see it.
Old 11-25-16, 06:13 PM
D
I was hoping that was a standard seal that was available online. Is that possible?
Old 11-25-16, 08:59 PM
cheese's Avatar
Possible but you'll probably have to make measurements and match it up. I don't know that you'll be able to find the details any other way.
Old 11-26-16, 03:30 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Good luck in finding the part. I took a rather new Husky pancake compressor out of service for a client, replacing it with a new one. So I decided to rebuild it. That was in June. They sent the wrong parts, don't answer emails or phone calls, and basically don't have any idea how to fix it. As Cheese says, for $80 it is better to scrap it and buy a new one, which I will do when I get my $80 back from the manufacturer for the wrong parts
