Snowblower problems
Old 12-17-16, 02:32 PM
B
Snowblower problems
My snowblower will only start when I put starting fuel in the carburetor and but after a few attempts it will usually run without a problem just the start up is giving me issues?
Old 12-17-16, 03:50 PM
BFHFixit's Avatar
Could be a choke/primer issue however equipped...is this by chance a Detroit diesel in a Mac Dump Truck attachment....?
Old 12-17-16, 04:24 PM
Received 125 Upvotes on 110 Posts
99% of the time it's a fuel issue.
Time to have the carb. rebuilt or replaced.
Been using ethanol fuel, stop it or at least an additive to conteract the effects of it.
Old 12-17-16, 04:58 PM
B
Its an old Arien snowblower. I already put on a new carburetor and the new carb is giving me the problem. I know it's getting fuel as I see it coming out of the jets when I pull the pull string. I have also tried messing around with the fuel mixture and idle mixture screws but can't find the right spot. The manual calls for a 1 1/4 turns out on each and still gives me an issue.
Any ideas?
Old 12-18-16, 10:09 AM
O
Received 8 Upvotes on 7 Posts
I would be looking very closely at the choke. Sounds to me like everything else is working fine.
Old 12-18-16, 01:44 PM
Received 3 Upvotes on 3 Posts
I'd like to see how you make out. I have a (retired) 1988 Ariens snowblower that had similar symptoms. It would start, run - but as soon as it encountered a load it would stall. I'd like to get it going again, I kinda like it better than the 3 year old Craftsman snowblower I have (that already needed a replacement recoil rope)
Old 12-30-16, 09:56 AM
B
My issue has to do with the choke shutter. When I purchased and installed the new carburetor it had me install the old shutter on the choke and it wasn't the exact same size so too much air is entering the choke throttle body. Where can I purchase a new choke shutter? Below is the part number for the new carburetor I purchased.
631794A
