Honda snowblower carb problem
Old 12-27-16, 07:11 PM
A
After not storing my snowblower for two winters properly...machine wouldn't start...so having some mechanical abilities I took carb off and cleaned the ports and main jet and reassembled unit...fires up on 1st pull....
But will only run on full choke...even after warm-up, any other setting than full choke machine dies. Bad gaskets? (There are 3 between block, carb, choke arm, cover....) what am I missing?
Old 12-28-16, 06:01 AM
P
Received 2,222 Upvotes on 1,983 Posts
Go through the carburetor again. It sounds like a passage or jet is still clogged.
While you have the carb off take a look at the fuel tank and fuel lines. Make sure the inside of the tank is clean and that the fuel is new and fresh. If you had a layer of varnish develop on the inside of the tank I would replace all the fuel lines and clean out the tank. When the varnish flakes off the bits can travel down the carb and clog a jet.
Old 12-28-16, 11:42 AM
A
Thank you! I will check that out tonight...I looked it up and didn't realize that there was a second jet there...I'll keep you posted
