Need to replace 16 amp pushbutton switch in snowblower
Hello,
I have a Toro Powercurve electric snow blower with a handle bar switch. It is a DEFOND 125 v/16 amp pushbutton switch DGH-2126-19. I am not able to find exact replacement and looking for help before the next snow storm here in NJ.
Since the switch is in the handle bar assembly, having exact replacement is the most ideal solution but if someone has any other creative ideas (safe for operation) for me to consider, I will appreciate anything you can help with here. Thanks.
PartsTree.com seems to have replacement parts for these, but you will need exact model number and serial number. Seems like the switch is only sold as part of a wire assembly, not by itself, but that will probably be easier than trying to find a matching switch.
I received the switch now and realize that its not easy to find any How-To videos on YouTube for how to replace the switch. There are no screws for the switch contacts but just the holes (2 for Line and 2 for Load). I am not sure how will the wire stay in place when inserted in this holes. Similarly I have to carefully remove the wire from old switch as length of the cable is limited due to need to fit that in snowblower handle housing. Any help is appreciated.
A picture would sure be helpful. http://www.doityourself.com/forum/electrical-ac-dc/534445-how-insert-pictures.html
It looks like the wires just "push-in" on the bottom of the switch.
That would mean there are visible metal tabs that get pushed in with a small tool like a screwdriver to release the wire.
PJMax, Thanks again.
Here's the pic. I used the flashlight and with your response, it makes sense that I may need to push down on metal contact to release the wire.
