14" chain saw--gas and oil specs?
's Avatar
04-28-01, 10:42 AM   #1
When using a small chain saw, what type of oil should be used? My chain saw has a gas tank and a seperate oil tank. Do I just put gas in the gas tank or do I use an oil gas mixture? What about the oil...should I use two cycle?
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
04-29-01, 05:59 AM   #2
Hello: shay
The engine needs an oil fuel mixture per the owners manual instructions. Use any brand 2 cycle oil and closely follow the mixture ratios recommended. The fuel oil mixture goes into the saws fuel tank.
The other oil tank is for bar and chain lube. In this tank you should use any brand of bar and chain oil. Do not use ordinary motor oil. It does not have enough stickiness to adhere to the bar and chain.
The bar and chain oil tank may also have a manual pump and well as an automatic oilling system. Use both. Failure to adequately lube the bar and chain will drastically increase the wear rate. Overheat the bar and chain which will also cause the chain to stretch and sag away from the bar excessively.
Regards and Good Luck.
Web Site Admin, Moderator Hiring Agent, Host and Forums Manager. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician. Fast, Fair, Friendly and Highly Proficient...
Don't Take Freedom For Granted. Thank A Veteran. Need an Employee? Hire a Veteran
Not only is a mind a terrible thing to waste, it's like a parachute.
It doesn't function until it's OPEN.........
Elvis. "The Sun Never Sets On A Legend."
Gun safety is using BOTH hands!
Driving Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
hDbLoOdTrAiL01's Avatar
02-22-07, 02:58 PM   #3
one more thing with that saw. keep the chain tight, you should only be able to pull it up about 3/4 of an inch with your fingers (pinching it). too tight or too loose chews up the bar,wears out the chain and is absolutley no good for the saw. oh yeah... buy a set of chainsaw chaps. they are great for keeping you warm, kneeling down on rough ground, they keep you a little dryer in the rain, keep the thorns off you, and most importantly they stop a chain!
good luck
puey61's Avatar
NY
02-22-07, 06:24 PM   #4
Old thread.
