Idler pulley adjustment
Old 04-03-17, 12:03 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Doing some tune up on my walk behind mower, replacing the main hydrostatic pump belt.
There is an idler pulley that needs to be tightened and it's attached to the main chassis with a carriage style bolt.
The problem is the bolt goes into a slot and I dont have a tool to add tension to the pulley to get it anywhere close to the original position.
Figure I need some type of tensioning tool, something like this but not having any luck searching, what are these called?
Old 04-03-17, 01:03 AM
cheese's Avatar
Received 134 Upvotes on 123 Posts
The one in the first picture is a bolt, nut, washer, and socket with a couple pieces of wood. It would be terribly easy to build one like it yourself.
Old 04-03-17, 01:21 AM
Received 3,758 Upvotes on 3,369 Posts
That Evil spreader was used on belt drive bikes.
Pulley spreader. Just about an extinct item now. J.C. Whitney used to carry them.
Similar but too long.....
https://www.mscdirect.com/webapp/wcs...tails/35438209
You're pretty handy. You could make something using a turnbuckle.
Cut the ends off and braze on your own half round fittings.
Old 04-03-17, 08:39 AM
G
Received 28 Upvotes on 27 Posts
I agree with cheese, my kind of fix. Have a good one. Geo
