Using Troy Bilt PW without hose hookup?
Old 04-18-17, 03:02 PM
C
When I bought my Troy Bilt 2800 power washer from Lowe's I was told I could could use it without being hooked up to a water hydrant if I drew water from a unpressurized tank, like a 15 gallon tank.
After burning up a pump in another washer due to restricted water pressure I'm reluctant to risk doing THAT again.
Any thoughts or opinions?
One of the projects I wanted to do was power washing our family grave makers.
Old 04-18-17, 03:13 PM
Received 824 Upvotes on 722 Posts
maybe for a few minutes, I wouldn't run a pressure washer unless it was connected to a continuous flow of water! btw- welcome to the forums!
I'd use a pump up garden sprayer to clean the grave stones.
Old 04-18-17, 03:17 PM
BFHFixit's Avatar
Pressure washers do not "draw" water. They require 2-3 gallons/minute usually and I think most might state 5 gpm. You might be able to accomplish this with a big enough head tank with gravity providing the flow. A 15 gallon tank would be used up in only a few minutes.
Old 04-18-17, 10:29 PM
cheese's Avatar
Received 141 Upvotes on 130 Posts
If you did this with a mobile tank, you would need to either pressurize the tank to 60 psi or so and maintain that pressure, or run a large pipe to the pressure washer, maybe 2" inside diameter or larger to keep the water supplying the pump faster than the pump is taking it. You'd also have to be sure there was a good vent for the tank and to keep it open while in use.
