Craftsman Lawn Mower runs 2-3 minute and then stalls slowly
Old 05-07-17, 09:10 AM
I have a 2 year old Craftsman rear wheel drive lawnmower with a Briggs engine. The Mower will start and run for about 2-3 minutes. Then it will stop. I believe it to be a fuel or air problem. This is what I have done so far.
Replaced all the gas and fuel. (thought water may have been in it)
Replaced air filter.
Replaced spark plug
Checked sheared flywheel key and its fine.
Cleaned carbeurater
Checked cap to the gas tank. I ran gas out of the tank in the line and the flow didn't stop or slow down at all so I believe the fuel cap is ok.
Last year it used to run for 30 minutes and then stop during fall and this year it runs only 2-3 minutes. Once it stops if i immediately try then it will stop in 4-5 seconds. After it stops if i wait 10-15 minutes then it will run for another 2-3 minutes.
Any other words of wisdom or other thoughts to consider would be great. It is hard to mow your lawn when the mower stops every 2-3 minutes.
Thanks in advance for any advice
Old 05-07-17, 11:15 AM
V
Received 2 Upvotes on 2 Posts
When you say "the gas cap is okay", I'm assuming that means you know that it's well vented and not creating a vacuum which slowly starves the carburetor for fuel ?
Old 05-07-17, 11:48 AM
cheese's Avatar
Received 134 Upvotes on 123 Posts
Sounds like a swollen fuel line or restriction between the tank and carb bowl.
Old 05-07-17, 12:49 PM
Yes that is correct it is not creating a vacuum because I tried starting with loose cap and problem still persists.
One thing i forgot to mention is I had oil flooding into air filter last year.
