Still fs81 weedwacker carburetor question
Old 05-23-17, 08:58 AM
ikleiman's Avatar
Hi,
As a novice do it yourselfeor, I made a foolish mistake and now I have a question. I was trying to remove the fuel line to the carburetor and in haste, I ended up prying off the part of the carburetter that connects to the line. I was able to tap it back in and re-connect the line. The fit is tight and it seems ok; but I wonder if I did some damage inside. Is there a clip or something that might've come off inside the carb?
Could I try starting the engine without disassembling the carb? That's what I'd like to do.
It's a Walbro carb. I can send a photo if necessary.
Thanks for the help.
Ian K
Old 05-23-17, 01:02 PM
Received 3 Votes on 3 Posts
Run it, I think they are sorta sweeged (sp) in at the factory if it falls out or leaks worry about it then and maybe put some JB weld around it. Have a good one. Geo
Old 05-23-17, 01:44 PM
ikleiman's Avatar
Thanks! I really appreciate the help.
