John Deer LA135 no gas flow from tank to fuel filter
Old 06-05-17, 09:38 AM
Hello,
Can't get John Deer LA135 22HP Briggs to run except when I prime carb.
Here is what I have done:
1. Blew gas line out to where I could see gas sloshing in tank so I know it's not clogged.
2. Took gas line off at carb to see if fuel pump is working and it is.
3. Put on a clear fuel filter on so I can see the gas flow. There isn't any.
4. Check air hole in gas cap and it is not clogged.
So for whatever reason I am having trouble getting gas from tank to fuel filter.
Any ideas?
Thanks
Old 06-05-17, 11:57 AM
cheese's Avatar
Received 22 Votes on 19 Posts
Replace the fuel line. It gets old, the inner lining swells and closes off the flow. Blowing through it makes it open but it closes when the pressure is gone.
Old 06-05-17, 02:44 PM
Received 42 Votes on 37 Posts
Did you replace the fuel filter that was already on it or add another one?
100 % sure you installed the filter in the right direction?
There should have been a arrow on it showing direction of flow.
Old 06-06-17, 05:50 AM
Thanks for the tips. Getting a new fuel line today. Yes, I did replace the fuel filter and made sure the arrow is pointing towards carb for correct flow. I am taking carb apart and cleaning while I am at it just to be sure float is working right and jets are clear.
Old 06-07-17, 06:40 AM
Here's an update...took carb apart and cleaned it. After I got it put back together before putting on new fuel line I turned the key to see what would happen. It fired right up and ran. Motor surges at first each time I start it before it levels out which I imagine is due to limited fuel line flow. I'll replace it soon. Anyway, got the overgrown acre of yard knocked down. Thanks
Old 07-23-17, 04:46 PM
It ended up it wasn't a corroded fuel line. Somehow the carb jets wound up in the float bowl. I have no idea how it was running at all. Runs perfect now.
