3.5 hp B&S leaks gas from carburetor when priming
Re: push mower with a B&S 3.5 hp engine, Model: 95902, Type: 3107 01, Code: 96050451
When priming, gas leaks from the carburetor below breather connection. There are two small holes there, obviously by design, both plugged with what look like a tiny stainless balls. The one just below the breather leaks when pushing the primer bulb. When one plugs the hole with a finger, the carburetor can be primed just fine and the engine starts without any problems.
What are those holes for and how to fix the leaking one?
