Corrosion on metal battery holder?
Old 06-19-17, 05:43 PM
Q
Received 1 Upvote on 1 Post
I'm getting corrosion on a weird part of the battery not connected to any terminals. Any ideas what is causing this?
Old 06-19-17, 06:26 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Corrosive gasses from the battery while it is being charged? And there may also be a very tiny difference in potential that is also helping cause it.
My flat stamped steel hold down has been dong that since it was probably 5 yrs old. I clean it, wire brush it, sand it, acid dip it, neutralize it, paint it with regular paint, bedliner, flexible trim paint, plastidip, whatever. It still comes back eventually. Most times I just pour some cola on to clean it up a bit then rinse with water and forget about it til next time I have the hood up. I've got a rigid piece of plastic I'm going to try to modify next time and just replace the metal piece completely.
Don't know whether sealed batteries have the same issue...probably not.
Old 06-19-17, 06:49 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Battery acid coming from the caps and seeping across the top is contacting the metal bar and causing the corrosion. Overfull batteries or overcharging can contribute to this. I see traces of the wetness on top of the battery between the caps. Sealed batteries don't do it as much.
