starting issues?
Old 07-04-17, 02:32 AM
biketrax's Avatar
Received 4 Upvotes on 4 Posts
starting issues?
My Honda HR214SX has not been able to start since I propped it back raising the front about 10 inch while I removed and sharpened the blades. IT was working fine before that. tried checking some obvious fuel spark air etc. thought i may have kinked a cable or hose?
It runs about twenty seconds then putters out like a fuel issue ( which I doubt it is) in choke mode. When I reposition throttle into run it hesitate and stalls, same if I keep it in choke.
I have played with the governor/ throttle directly a bit and seems to react a bit.
So I am going to take the bowl off to see if the float is stuck .
any suggestions welcomed.
thanks
Old 07-04-17, 03:28 AM
V
Received 3 Upvotes on 3 Posts
I know nothing about Hondas; but everything you mention points to the engine now being starved for fuel when you stop choking it.
Is there a fuel filter, which may have become clogged with debris from the fuel tank that had been stationary but moved when you propped the unit up to sharpen the blades ?
Could the fuel cap be like that on a B&S and create a vacuum if not vented ?
I'd check the fuel line/filter/tank for new blockages . . . . maybe do a back-flow to remove any new obstructions.
If that fails, only then would I go the other direction and check the fuel bowl (if it has one) and needle valves . . . . but this is where having a fuel filter begins to pay off by preventing debris from even getting that far.
Have a Happy 4th of July . . . . I'll be swapping out a Master Cylinder on my car.
Old 07-04-17, 07:28 AM
G
Received 31 Upvotes on 29 Posts
You probably shifted some debris in the bowl when you tilted it back and then the carb sucked it up the nozzle to create your condition. Below is a link to a video to clean honda carbs. Have a good one. Geo
https://www.youtube.com/watch?v=tlRZitBposI
Old 07-04-17, 09:18 AM
biketrax's Avatar
Thanks Resolved
Dirty Carburetor Bowl! Very Dirty Had not been cleaned in 4 years Naughty me! Well.... Self Pardoned due to injury!
Will also add a filter first chance I get!!
Just for curious minds same ole stuff settling on the bottom of the bowl causing dirt and rust etc.!!
Cheers and thanks!
Old 07-04-17, 04:31 PM
V
Originally Posted by biketrax
". . . Will also add a filter first chance I get!! . . ."
I use those cheap clear motorcycle fuel filters on all of my yard equipment; from snowblowera and tillers to trimmers and riding mowers . . . . would probably even work on a Honda !
By shopping around, I pay less than $1.00 apiece, shipping included (and sometimes clamps).
