Deere 14SE 21" walk behind
Old 07-05-17, 06:56 PM
2
Looking for part numbers for the subject mower:
The mower generally runs well but the needle / float is beginning to act up. Every once in a while the needle will not close fully and the carb overflows some gas. Typically only an ounce or two but even that small amount is enough to stink out the garage. Other, than that issue the mower runs good for its age. Now to the part numbers. I called the local Deere dealer and they want $36.xx for a rebuild kit which seems a little excessive. I was wondering if anyone had a Kawasaki part number or a Briggs number for a cheaper kit. I also require the carb to block gasket as I have little hope of salvaging that gasket when I take it apart. The Deere dealer listed that single gasket right at $7. Prices seem a little high and I was hoping to order the stuff from Amazon if possible.
Oh, the engine is a FC150V - ES01.
Thanks,
Steve
Old 07-06-17, 06:29 AM
W
Received 63 Upvotes on 55 Posts
Mower
What is your question? . . . . .
Old 07-06-17, 07:22 AM
V
Received 3 Upvotes on 3 Posts
Originally Posted by 2ndgencamaro
". . . I was wondering if anyone had a Kawasaki part number or a Briggs number for a cheaper kit . . ."
So which carburetor do you have . . . . Briggs or Kawasaki ?
Old 07-06-17, 11:57 AM
cheese's Avatar
Received 141 Upvotes on 130 Posts
If it's a kawasaki, no briggs parts are going to help. Looks like you can buy the entire carburetor for $13 on ebay with free shipping. A cheap chinese replacement I'm sure, but if price is your primary motivator...
Comes with gasket.
CARBURETOR CARB GASKET FOR KAWASAKI FC150V 4-CYCLE ENGINES 15003-2364 OEM O4H0 | eBay
Old 07-07-17, 11:01 AM
2
Yes, it is a Kawasaki engine. I do not think that Deere installed Briggs engines on any of the 14SE mowers. I only mentioned Briggs as they make rebuild kits for many engines. I was hoping that they had one for the carb on this Kawasaki engine and that would be cheaper than a Deere kit.
Cheese,
Have you used any of these cheap knock off carbs?
Thanks,
Steve
Old 07-07-17, 11:41 AM
cheese's Avatar
I've used one or two, they worked fine.
Briggs only makes parts for briggs engines.
