23 hp briggs&stratton don't shut off
Received 0 Votes
i have a huskavarna lawn tractor when i turn off the key the engine wants to keep running until it runs out of fuel also it is not charging. i have replaced the ingition switch and solenoid. with no luck.
It sounds like you might have the ignition switch wired incorrectly or some other wiring problem. Post your mower's model and serial numbers and the experts will be able to answer any specific questions you might have.
All the " off" position on the switch does to actually kill the engine is to connect the kill circuit from the ignition coils to ground.
If you have the solenoid on the carburetor it would cut the current it. That prevents after running and backfiring after shut off. It doesn't control fuel to the carburetor, but controls movement of fuel through the carb. It has to work, but it's not responsible for the actually shutoff of the engine.
The kill circuit is for shutting down the ignition.
Since the engine is running OK the circuit from the coils to the switch to ground has a break in it. It may be the way you have wired the switch.
At the first connection after the coils, take that apart and check for continuity going toward the switch (with the switch turned off) to ground. The ohms value should be a little over zero.
If that checks out, go the other direction toward the spark plugs. Check at the break to the lead wires at the spark plugs. You should have continuity there too. One of your circuits will show faulty. Probably the one going towards the switch to ground. The kill circuit may not be passing the switch to a grounding wire or the wire may not be grounded on the far side of the switch.
Originally Posted by rich2
". . . it has to be in the wiring somewhere because im still not charging either . . ."
I once burned out an ignition coil when re-wiring a former recoil starter mower to an electric start, and mixed up a couple wires in the wiring harness.
The lack of a charge circuit together with the absence of a kill switch is a clue that somethings reversed.
That is unusual. With the coils grounded they can't fire, without regards to the charging system. If you took the small wire coming from the coils, separated it at the break and led that circuit to ground, the engine would die from no spark. It can't work any other way short of a gremlin.
The charging system has nothing to do with that ignition system. It only works on the battery/accessories. The ignition is self contained with the coils, plugs, and the kill circuit.
Does it keep running normally or does it buck and chug (diesel?) If the latter check your fuel solenoid to see if it is stuck open...
I just had one today on a Kohler and it would diesel when it was hot...usually these stick closed and the engine will not start, I think this was the first one I found stuck open.
