Help replacing simplicity snowblower auger shaft oil seals
Old 07-12-17, 08:12 PM
Simplicity Snowblower
Model: 1691413
Last winter one of my snow tire chains came off, i ran it over, and it got stuck in the auger. I was able to remove it, and all is well.
However, I think that event damaged one of the auger housing oil seals, since it leaks now.
I got two new seals today, but it looks like seals have a metal protective cover. How do I remove this cover so that I can replace the seals? I can't tell if it unscrews, or presses out. The attached picture is of the seal cover that isn't dented/damaged.
Old 07-12-17, 08:52 PM
It looks similar to an auto inner wheel bearing seal which is pressed into the hub. To remove it, I would mount it backwards on the shaft, put the nut on it & pull it. Not being able to see all the parts, I don't know if something similar can be done. In other words, you would be pushing it out from the other side.
Old 07-12-17, 11:07 PM
Success, thank you. They just pressed out. The outside of the old seals looked a little different from the new ones, the old ones were indented in a very uniform way, as you can see on the old seal on the right.
Old 07-13-17, 07:07 AM
Well done.
_________
_________
