My Toro mower suddenly quit - thoughts?
Old 07-25-17, 09:23 AM
I have a Toro Recycler about 9 or 10 years old. I've changed the oil in it maybe 5 times but haven't maintained it as well as I probably should. Last oil change and new spark plug was spring 2016. I saved the old spark plug because it still had some life in it. All season, it has taken about 3 pulls to get the engine running.
Yesterday I poured new gas into the tank and fired it up. Started normally (took 3 pulls) and ran for about 1 minute and then abruptly died. Was not making any unusual noise at the time. Now I can't get it to start. Doesn't even make noise when I pull the cord like it is trying to start. Blade is not obstructed and still rotates by hand.
My first thought was spark plug, so I put the old spark plug in from before the last tune up. No difference.
Thoughts? I don't want to put significant money into fixing up this mower because I planned to get a new one next season anyway (hence not bothering with the spring tune up this year). But if this is a cheap fix I'd gladly do that so I can get through the rest of the season and sell it for a little money next spring!
Old 07-25-17, 10:53 AM
cheese's Avatar
Received 55 Votes on 50 Posts
Does it have compression? Might just be some water that got poured in when you filled the tank before starting.
Old 07-25-17, 11:44 AM
A
Received 72 Votes on 65 Posts
Doesn't really sound like it, because some air will usually get through eventually so that it will start again after a bit, but try loosening your gas cap. Sometimes they get dirty, not allowing it to vent, leaving you with a vacuum in the tank.
Old 07-25-17, 03:33 PM
cheese's Avatar
It died shortly after filling the tank and hasn't started since. Water in a carburetor doesn't dry out, it sits in the bowl. It's heavier than gas, so it stays there in the bottom, clogging the jet.
Old 07-25-17, 03:46 PM
BFHFixit's Avatar
What engine does it have?
edit: (cheese posted while I was contemplating )
Dribble some fuel or a short squirt of starting fluid in the carb, if it fires then it is most likely fuel/carb related, if not and by chance it is OHV, pull the valve cover see if the rocker arms and pushrods are still in place.
