17.5 Briggs backfiring and will not run without choke closed
Old 07-29-17, 03:02 PM
I have 17.5 Briggs engine on a LT1000 Craftsman mower. Got it from a friend has not run in 2 years. Changed the fuel line. Added new gas cleaned the carb. Changed the oil and spark plug. Started it yesterday. Ran like a Cadillac for about 10 mins the started surging and died. Cleaned the carb again. Checked the fuel solenoid. Starts and runs again but have to have the choke completely shut off. Runs rough and pops alot. Model # is 31c707. Thanks for any help
Old 07-29-17, 03:21 PM
Read some other threads- pull the small wire of the coil. Still surged and died with choke open. Noticed alot of white smoke coming out of intake pipe when the engine dies.
Old 07-29-17, 08:49 PM
cheese's Avatar
Received 45 Votes on 40 Posts
Sounds like you still have a carb restriction.
Old 07-30-17, 08:48 AM
BFHFixit's Avatar
Head gasket .
Old 07-30-17, 05:31 PM
Yep pulled the head off and found a bad gasket. Thank you
