Honda Generator - pop noise when starting - then starts and runs
Old 08-09-17, 10:43 AM
Hello,
I've been reading a few threads here re. small engine backfiring, and/or making popping noise while shutting the motor down. I haven't quite seen anything on making the popping noise while starting. So I'm not sure what to do in my situation.
Background:
I have a Honda generator, Model EM3000c (bought in 2000). It's been running perfectly well since then. I use it at the summer cottage occasionally (20-30hrs) to power my tools (saws, drills, etc). I also maintain it well - oil changes, clean air filter, spark plug, etc. At the end of the season - I add a fuel stabilizer into the gasoline.
Problem:
I've been using it for the past 2 weeks this summer - everything fine. Then just yesterday, the generator made a LOUD pop at the exhaust when I tried to start it. It didn't start in the first pull. So - I pulled the cord again. There was no pop and it started and ran fine.
As a "quick fix" and without searching the web, I changed the spark plug. The old plug was dry (from any fuel) and not particularly "dirty".
I pulled the cord again - no problem- no pop and ran fine.
Then the second time starting the generator - the loud pop sound came back.
I pulled it once more - it started OK and ran fine.
Question:
What's causing the popping at the start of the engine? What do I need to do to fix it?
Curiously - why doesn't it happen "every time" I pull the rip-cord?
What can I check on the engine?
Thanks.
Old 08-09-17, 02:36 PM
Received 28 Votes on 27 Posts
I would say a valve sticking open. You might try an oil flush or put some two stroke oil in gas 40:1 wouldn't hurt for a short time. Or put some Sea Foam in the gas.
Old 08-10-17, 01:14 AM
cheese's Avatar
Received 97 Votes on 90 Posts
Try a new plug. Champion or autolite recommended. If it continues, we can go further. Could be a sticking valve too like marbobj suggested.
