Are Small Engines Standardized? My Tecumseh Seized
Old 08-20-17, 12:32 PM
B
I have a go kart with a Tecumseh OHH65-71707C Power Sport engine that seized. This engine replaced a Tecumseh 5 HP many years ago and I had no issues with that replacement. My Tecumseh 6.5 hp engine is no longer made. I would like to find a suitable replacement that doesn't require extreme fabrication. Are these engines standard? Can someone recommend d a suitable replacement?
Old 08-20-17, 12:53 PM
cheese's Avatar
Received 45 Votes on 40 Posts
The mounting pattern is pretty standard among similarly sized engines. Check your crankshaft size and find another engine near the same hp with the same size crankshaft. Also check for clearance if you have anything near the engine that might interfere and make sure the exhaust is blowing the right way if it matters in your application.
Old 08-20-17, 03:44 PM
G
Received 11 Votes on 11 Posts
smallenginewarehouse.com might have a replacement for you. Have a good one. Geo
