Leaking pressure washer
Old 08-25-17, 05:24 AM
C
Troy Built pressure washer: Tremendous water leak around the Pump outlet tube, where it connects to the Pressure Washer. Any help appreciated!!
Old 08-25-17, 09:28 AM
P
Received 859 Votes on 792 Posts
Is it cracked or broken?
Post your model number or provide pictures so we can see what you've got.
Old 08-25-17, 12:38 PM
C
The model number is 020381-00. All the water leak is coming from the pump outlet tube where it screws into the pump. The leak starts as soon as the pressure starts building up after starting the engine.
Old 08-25-17, 07:12 PM
Received 1,476 Votes on 1,364 Posts
Welcome to the forums.
The DIY/moderator pic program is working again.
I added three pictures of the pump to your post. That pump is part # 206376GS and it appears that repair parts are not available for the pump. It just gets replaced.
It looks like the main body of the pump is one piece. Maybe you can describe in more detail where it's leaking.
