How to change oil on Billy Goat Estate vacuum?
Old 08-26-17, 07:58 AM
I
Received 1 Vote on 1 Post
Can't believe im stumped.....alongside of removing all the lower plastic, there must be a simple way of changing the oil on this 5.5 HP Briggs. Where is the drain plug? Not even stated in the owners manual...
Any input appreciated
Old 08-26-17, 09:12 AM
A
Received 5 Votes on 4 Posts
You'd think there would be a drain plug, with a hex head bolt, under the deck.
Failing that, get an oil change pump that you can put down the dipstick tube to draw the old oil out.
Old 08-26-17, 01:34 PM
G
Received 23 Votes on 22 Posts
On most of the newer engines you tip them over and pour the oil out the fill tube. Have a good one. Geo
Old 08-27-17, 09:22 AM
I
Ok, thank you....I will go with the oil pump.
