No spark, but still getting a shock
Old 08-28-17, 07:57 AM
C
Hi guys, I'm still having problems with my Wolseley merrytiller, tried to start it yesterday, it started for a moment or two, then stopped, I checked the plug and it was giving off a yellow spark, so I put in a new plug, but then I got nothing, put the old plug back and once again nothing, I have changed from points to magnatron ignition, any ideas?,it's a 1975 tiller with a Briggs 5hp engine, thanks
Old 08-28-17, 09:06 AM
Received 28 Votes on 27 Posts
Try a spoon of gas down the plug hole. It may be fuel related
Old 08-29-17, 04:00 AM
B
Received 182 Votes on 162 Posts
Your description is confusing. What is meant by “still having problems”? Do you mean there were problems before changing ignition and plug that still exist or the problems started after changing ignition and/or plug. Please clarify so I can comment.
Old 08-29-17, 04:40 AM
P
Received 1,571 Votes on 1,412 Posts
What do you mean by "still getting a shock"? Where and how are you getting this shock? Maybe the spark plug wire is bad.
Old 08-29-17, 01:42 PM
C
Hi beelzebob, what I mean is I put a post on a couple of months ago regarding the tiller not starting which I thought was the carb, which I have taken off, gave it a good clean, inserted a new diaphragm, and it still did not start, so then I checked for a spark and that's where we are now, when I first changed the ignition it worked fine, but it has been standing a while, but is has fresh gas inside,
Pilot Dane , I, getting a shock when I'm holdinig the plug against the casing and pulling the starter rope, thanks for trying to help me guys
Old 08-29-17, 05:51 PM
cheese's Avatar
Received 97 Votes on 90 Posts
Usually that's a sign of a bad condenser, but if you have electronic ignition, that's not part of the equation anymore. If you are holding the plug and getting shocked, then the plug isn't going to fire because you are giving the voltage a path to ground instead of it having to jump the gap in the spark plug. Check for spark with the electrode grounded to the engine and in the dark and see what happens.
Old 08-29-17, 06:06 PM
B
You are getting a shock because you are touching the high voltage conductor part of the plug or there is a crack in the insulation and the high voltage is arcing to you hand which is in contact with some part of the engine.
Since the engine has been sitting for a time, my guess is the carb is the problem. While cleaning and replacing the diaphragm are good corrective measures, they don’t fix everything. Many 2- stroke carbs have non-replacable check valves (operate with the choke function) and when they fail, replacing the carb is the only solution. If the spark plug is not wet with gas after choking and attempting to start the engine, replace the carb.
Old 09-03-17, 05:29 AM
C
hi guys, I've managed to find another carb but it is missing the fuel pick up pipe, is there a way to connect one I've seen on youtube where you can make one out of brake ling and fitting a plastic filter on the end, would this do, but can I disconnect the one on the old carb and fit it on this other one, please find pics enclosed
Old 09-03-17, 06:17 AM
V
Received 2 Votes on 2 Posts
Did someone tell you that the red one is the same casting as the plain aluminum one ?
I don't think it's the same carb . . . . might work; but there are differences.
Old 09-03-17, 06:18 AM
I wouldn't count on the replacement being in better shape than the one you have now.
Old 09-03-17, 12:18 PM
cheese's Avatar
Me either. Did you ever verify spark?
Old 09-03-17, 12:50 PM
C
Yes I had it running Friday, by dropping a drop of petrol in the top of the carb, all be it while the petrol was burned off, so it does seem like a fuel problem?, but unfortunately l'm at a loss what else to do, unless anyone has got any more ideas
Old 09-03-17, 10:26 PM
cheese's Avatar
Yeah, sounds like a fuel problem. Judging by the looks of it, I would work on cleaning that original carb more. Also, take a look at the tank. There is a small cup where the short pickup tube goes. Make sure there are no rust holes in it. If there are holes in it, it won't start or run.
Old 09-04-17, 03:40 AM
C
Thanks cheese, i will take a look at the tank, but it will not be before the weekend, i will keep you updated
Old 09-04-17, 05:35 AM
B
What diaphragm did you replace?
Old 09-10-17, 10:24 AM
C
I changed the diaphragm on the other side of the carb, which is not shown in the picture, one other thing can you dismantle the two drop down fuel pipes from the carb, or are they attached permantly?
