Electric starter turns but does not engage
Old 08-29-17, 12:58 PM
I have a Craftsman model 944.36210 Rotary Lawn Mower 725 Series Briggs & Stratton Engine model 128M05-0129-F1.
My lawnmower starter was working fine but suddenly when I stopped the engine and pushed the start button it made a whizzing noise but it would not engage the motor. The manual starter worked fine and I kept using it.
Is there an easy way to get at the trouble and fix it?
Thanks,
Bania
Old 08-29-17, 05:45 PM
cheese's Avatar
You'll have to look and see, but I'd say either the starter gear is broken or it's just stuck in the down position and needs cleaning.
Old 08-30-17, 09:17 AM
Thanks, I will check . Can I use WD-40 to clean the gear will it also lubricate or should I have to use special lubricant?
Old 08-30-17, 09:57 AM
cheese's Avatar
WD40 is fine
_________________________
Old 08-31-17, 09:06 AM
Thanks. I looked the problem is that the one of the starter motor screws has fallen off the other was loose. But I think the starter motor needs cleaning as well. Thanks for your help.
