JD L110 Issue
Old 09-18-17, 04:23 AM
JD L110 Issue
Another issue with my JD L110 (Koehler Command / Hydrostat). The tractor has been difficult to start. The engine will not start on choke, I have to turn it over a few times on choke and then switch to full throttle to get it to start. Gas will sometimes even blow out of the exhaust. Once started, the engine runs/idles very rough. Seems like every other second it wants to stall. The throttle seems to almost "bounce". It also seems to be running very hot; the exhaust pipe is white.
Any suggestions?
Old 09-18-17, 04:10 PM
Marq1's Avatar
99% of small engine issues are the carburetors. Sounds like a rebuild or replace is due!
Old 09-18-17, 04:45 PM
I agree 100%, been using ethanol fuel?
Little late now but find a place that sells non ethanol gas and have far less issues in the future, or at least add an additive that counteracts the effects of it .
Ethanol soaks up water, and destroy's the fuel lines.
Old 09-19-17, 10:49 PM
cheese's Avatar
It sounds like your carb is leaking gas into the cylinder while it's not in use. A new needle may fix it but I have found many that require a new carburetor to stop the problem. Check your oil, if it's gassy, change it.
