Finding Parts for a Briggs & Stratton engine on a Generac Generator
Old 09-19-17, 06:14 AM
Received 1 Vote on 1 Post
I don't give up on fixing much; but I'm about to give up on finding parts for the engine on this small Generac S2400 Generator.
The engine that powers it (powered it) doesn't have the standard B&S Model, Type, and Code Number and seems to defy the standard B&S Number system.
This Generac S2400 unit has a plate on the 5 HP Horizontal Shaft B&S engine saying:
Model: 9415-1
Series:: S-2452
Serial: 1157013
Volts: 120
Amps: 20
Watts: 2400
Can anyone de-code this to locate an engine Schematic and Parts Number identifier for this B&S Engine ?
I originally just wanted to replace the rusted steel gas tank; but now I wonder if I should even begin looking for what I thought might be standard B&S Parts.
Old 09-19-17, 06:37 AM
Old 09-19-17, 06:45 AM
Originally Posted by Donato
". . . Did you try that site? . . .
Yes . . . . and found NOTHING on the "engine" itself.
Old 09-19-17, 06:53 AM
XSleeper's Avatar
Received 303 Votes on 276 Posts
Try this:
https://www.ereplacementparts.com/br...390_26068.html
The actual model number of the engine should be on the shroud. On older engines it was often stamped in the metal by itself, sometimes near the plug wire.
Old 09-19-17, 11:19 AM
Originally Posted by XSleeper
" . . The actual model number of the engine should be on the shroud. On older engines it was often stamped in the metal by itself, sometimes near the plug wire . . ."
That was the 1st place I looked, and expected to find it.
Looking closely at the side of the shroud, I think there;'s a Generac Decal positioned right on top of the embossed B&S Model, Type and Code. I'll have to scrape it off.
Old 09-19-17, 11:26 AM
XSleeper's Avatar
You might be able to put a piece of paper over it and shade it with the wide side of a pencil lead.... might make an impression of the number that you could read without removing the decal.
