Hi Pressure washer question
Old 09-25-17, 01:30 PM
Hi All, correct me if I am wrong, when I am appling chemical through the downstream chemical injector only the chemical mix is being applied and no additional water is being added.
Thanks
Geo
Old 09-25-17, 01:58 PM
Unless I'm mistaken the chemical injector uses water to 'siphon' the chemical which would dilute it. I always use a pump up garden sprayer instead to apply the cleaner.
Old 09-25-17, 03:20 PM
BFHFixit's Avatar
In fluid dynamics, Bernoulli's principle states that an increase in the speed of a fluid occurs simultaneously with a decrease in pressure or a decrease in the fluid's potential energy. The principle is named after Daniel Bernoulli who published it in his book Hydrodynamica in 1738.
Same principle as a Carburetor: As the velocity of air increases through the venturi it draws fuel and creates a fuel/air mixture. Air is in sense a fluid just as water so the velocity of the water creates a low pressure drawing the chemical to create a mixture.
Old 09-25-17, 03:30 PM
So that being said, a chemical solution of 1:20 ratio is further diluted .
Geo
Old 09-25-17, 03:35 PM
BFHFixit's Avatar
