Lawnmower help
Old 09-30-17, 01:48 PM
N
Lawnmower help
Replaced fuel tank on Craftsman Briggs & Stratton Gold self propelled push mower because cap was stripped.
Fired up then died 3 minutes later.
Cleaned out entire carb...sprayed, air compressor, wire in tiny holes.
Changed spark plug and air filter.
STILL won't start??!!
Old 09-30-17, 04:02 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Is the fuel line open?
Old 09-30-17, 04:10 PM
N
Yes fuel line is open
Yes. Blew into..gas flowing into carb
Old 09-30-17, 05:11 PM
D
Received 190 Upvotes on 153 Posts
Faulty gas cap that wont vent?
Old 09-30-17, 09:29 PM
cheese's Avatar
Received 112 Upvotes on 102 Posts
Model number?
__________________
Old 10-01-17, 06:22 AM
P
Received 1,776 Upvotes on 1,588 Posts
In one line you say it fires up and runs for 3 minutes. Then you say it won't start. So, which is it?
Old 10-01-17, 11:06 AM
B
Received 235 Upvotes on 208 Posts
If the engine was running OK before changing gas tank, it should be running OK after the change unless you did something like bending the carb linkage or mounting the linkage in the incorrect hole, etc. Why did you change plug (not a bad thing)?
