John Deere rx75 tractor
Old 10-03-17, 10:12 PM
have a jdrx75 with 9hp kawasaki cust said replaced blade and all sudden no spark he put new coil new igniter and still no spark any ideas?
Old 10-04-17, 03:19 AM
Probably a safety switch. On a Kawasaki the igniter is the first check. After that the "suddenly no spark"s here seem to fall on the seat switch a lot.
Old 10-04-17, 09:01 AM
On the Model JD that I had if you removed the discharge chute it would trip a safety switch, maybe he accidentally tripped one while changing the blade. Have a good one. Geo
Old 10-04-17, 05:24 PM
there seems to be no switch from chute it has a bagger though and i took a look and seat switch isnt hooked up but i did notice under rear of tractor there is a harness that someone taped a jump wire across.
Old 10-04-17, 07:26 PM
BFHFixit's Avatar
Disconnect the ground lead on the coil and check for spark.
