Toro HMR running issue
Old 10-15-17, 08:31 AM
I have a 1989 ToroHMR 1600 16 hp Kohler twin engine, that was completely rebuilt two years ago, and then went into storage
When I fired it up recently , I had a problem getting it to rev up to the right operatiing rpm. I took the carb apart and cleaned it, which made no difference, and while testing I noticed an intermittent back fire out the exhaust that wasn't there before. I'm thinking it might be a sticking valve or ? Any advice as to where to go looking next?
Old 10-15-17, 09:25 AM
Fuel issues would cap rpms and can account for the backfire. It could be a sticking valve, but If it ran well after the rebuild, I would suspect the carburetor.
I'd run some Sea Foam through it in the gas a little in the oil. That may take care of it - it works in a lot of cases.
Old 10-15-17, 01:13 PM
HMR Running Issue
I was running late when I posted my initial thread. I CAN get the engine to throttle up If I take the air filter off. (It is a new filter) There is one needle valve on this carburetor that USED to affect the running efficiency when adjusted. I does NOT affect anything now until I turn it to the completely closed position (which stalls the engine) The needle valve position does not help if the air filter is removed however. It wont hurt to take the carb off again and re treat it with carb cleaner if you think that would cure it. A lot easier than doing another valve adjustment)
Old 10-15-17, 03:24 PM
Put some Sea Foam in it - always a good first try.
Old 10-15-17, 07:23 PM
cheese's Avatar
Sounds like a clogged carb to me.
Old 10-16-17, 07:30 AM
Ok Seafoam in the gas, and soak the Carb in Cleaner and flush it again! Ill let you know!
