husqvarna 357
Old 11-16-17, 04:03 AM
husqvarna 357
I have a Husqvarna 357 chain saw that I have had for years. Great saw but I keep scorning the cylinder. I do replace it myself but this is the third time in the last few years that it has happened and I do not use the saw much.
recently the saw had been sitting for about 1 year plus. I drained the gas and put in fresh new 93 octane with 50 to 1 Husqvarna oil. It ran great for about 1/2 hour and then stalled. I did a compression test and it was low, took it apart and the cylinder was shot.
a) what am I doing wrong
b) where and what brand parts should I replace them with
Thanks in advance
Old 11-16-17, 06:32 AM
Most of the time scoring comes from the fuel/fuel air mixture. In hot weather it's a good idea to run a heavier oil to gas mixture.
In your case, assuming the parts and assembly work went OK and a new piston and barrel was used, I would say you have the fuel/air mixture set too lean for high rpms. You may want to turn the High rpm screw on the carb out until you get a slight drop in rpms.
Old 11-16-17, 11:33 PM
cheese's Avatar
I agree with marbobj ^^^^^^^^^^^^^^^^^
Old 11-17-17, 02:23 AM
besides the fuel mixture adjustment you may have an air leak witch is causing it to run lean would probably at least pressure test for leaks after repair.
Trackbacks are On
Pingbacks are On
Refbacks are On
