sears 18hp mower
Old 05-09-01, 01:15 PM
I have a sears 18hp riding mower with a 46" deck. I now, this year, have a constant "squealing" sound. I assume it is the mower belt, but cannot figure out how to adjust it. the book is useless and sears wants $88 just to come out. it works fine as long as i do not try to cut grass with it. it is a model 917.258685--and the biggest mistake i made two years ago. any ideas on what to look for or do? it cuts grass, but i get a headache listening to the high-pitched squealing.
Old 05-09-01, 06:44 PM
Sharp Advice's Avatar
Admin Emeritus
Hello: cziembo
It may not be a belt squeal at all. Could be one of the pulleys is loose on it's shaft or the quill pulley on the engines crankshaft.
Usually they loosen just enough to cause a squeal. There will be a hex head set screw or maybe two screws on the quill pulley. Also check the blade adapters. Same condition may apply there.
Another thought is a blade or pulley clutch, belt pulley or bearing.
__________________
Regards and Good Luck.
Web Site Admin, Moderator Hiring Agent, Host and Forums Manager. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician. Fast, Fair, Friendly and Highly Proficient...
Don't Take Freedom For Granted. Thank A Veteran. Need an Employee? Hire a Veteran
Not only is a mind a terrible thing to waste, it's like a parachute.
It doesn't function until it's OPEN.........
Elvis. "The Sun Never Sets On A Legend."
Gun safety is using BOTH hands!
Driving Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Trackbacks are On
Pingbacks are On
Refbacks are On
