MTD Tecumseh 8HP Engine Dies Under Load
Old 01-27-18, 10:27 AM
B
I have a MTD snowblower with an 8hp Tecumseh engine. I have a problem with it dying under load. I cleaned the carb and it did nothing. I replaced the carb with a brand new one and also replaced the fuel lines from the gas tank to the carb. I have the new carb tuned pretty good and the engine runs very well until I put it under a load. Once under a load it bogs down and will stall if you keep it under a load. Spark plug is in good shape. Haven't tried replacing that yet. I'm not sure what else it could be or where else to look. Thanks in advance.
Old 01-27-18, 10:39 AM
Received 14 Votes on 13 Posts
Replace the spark plug and put some Sea Foam in it. That may take care of it.
Old 01-27-18, 11:35 AM
B
I will try that thanks for the idea
Old 01-27-18, 11:40 AM
I see you put a new carb on it. If that's brand new, turn out the screw under the float bowl about 1/8 turn at a time until it runs under load.
Old 01-28-18, 02:50 AM
Marq1's Avatar
Received 392 Votes on 366 Posts
Should be a governor on the carb to adjust throttle as load is applied. Check to see that it;s not bent or sticking!
