Kubota ZD326 cutting bad put this on the spindle did fine what is it called
Old 04-08-18, 01:25 PM
Couple of years ago my mower was bauging down bad cutting.. Took it in guy said right off you need a piece on the spindle???
he looked at it and put a round piece above the nut it did fine..
Now it is doing it again, Im putting on new blades and want to go ahead and put on 1 on each spindle..
anybody know what this is called what it is???? Id be great full
Old 04-08-18, 02:43 PM
The flat washer in your hand? Looks like the fiber washer that drives the blade. Without it the blade would slip.
Old 04-08-18, 02:55 PM
So I get one of these, do i put on ABOVE the blade are right below the blade?? I was told it was a blade adapter and a blade spacer so far.. Thanks for the reply
Old 04-08-18, 03:41 PM
BFHFixit's Avatar
Looks like what grasshopper uses. It should go between that adapter and the spindle on the side with the raised middle.
Old 04-08-18, 03:58 PM
Do you have any other model numbers/letters to go with the ZD326 and the mower deck ID.
Old 04-08-18, 04:07 PM
Fixit above the blade or below the blade??
Old 04-08-18, 06:30 PM
BFHFixit's Avatar
Above the adapter.
In your first pic it looks like you are putting it on where it should go, then that adapter mounts to the spindle with the fiber in between.
Old 04-09-18, 05:43 AM
K Tks everybody for the input on this
Old 04-13-18, 09:15 AM
Guys look at my CUPS under my ZD326 deck.. 2 are about gone..... 1 is gone whats in my hand??
how do you replace these????? anybody know is there a washer that goes back on??
Look at that first pic the cup is different than the others?????
Old 04-13-18, 11:08 AM
That first pic is where the CUP HAS COME OFF....
Old 04-13-18, 11:15 AM
BFHFixit's Avatar
That cup should just pull off and have a fiber washer inside.
Those cups spin with the blades and are just plastic, they will eventually just disintegrate to nothing more than a plastic disc the size of the fiber washer.
They are a consumable item and do help the life of the spindle.
Old 04-14-18, 02:41 PM
my cups were all metal,, I went ahead to replaced all beveled washers and got 3 new cups. One cup was bent on so tight with no bottom. It would not come off.. I had to get a screw driver to pry it off.....
Now i'm now in good shape it got new blades new cups and washers
Guys with kubotas check your cups even replace with 500 hrs on it is what i was told at stealer, I mean dealer..
