lawn mower / weedeater
's Avatar
05-13-01, 09:00 PM   #1
I cant get my lawnmower are my weedeater started.
The lawnmowr just want crank. I have changed the sparkplug
and changed out the gas. it started when I left it out side also
my gas wed eater will start but when you try to give it gas it dies. steve
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
05-14-01, 07:11 PM   #2
Hello Steve and Welcome to the Do It Yourself Web Site and for posting your question in my Small Engine forum.
The weed eater string trimmer most likely has a restricted high speed fuel circuit within in the carbs internal fuel system. To correct this problem the carb will require removal and an internal carb cleaning {boil out in mechanics lingo} and a new kit carb kit parts installation.
If the mower will not crank, you'll first need to check for external mechanical reasons. All found okay there, read the recent posting on this subject matter of internal engine problems.
Post back the results of your findings.
Good Luck,
Tom_Bartco
Accurate Power Equipment Company.
Small Engine Service and Repair Technician.
Personal Quote:
"If it ain't broke, don't fix it!"
