Diode
Diode
Hi All, what can happen if I don’t install a diode in the charging circuit on a B&S Vanguard V Twin? It seems to be charging OK
Geo
Geo
Not only will it discharge the battery, it will fry the stator and/or wiring to it. Possible fire risk.
I don’t understand why if the engine is equipped with a regulator/rectifier why is the additional diode necessary, Kohler engines do not show a diode in the charging circuit but there is a option to install one in the kill switch circuit.
Geo
Geo
I'm not familiar with any of the ones using a regulator/rectifier also using a diode at the same time. I didn't know your engine was equipped with a regulator. Some briggs twins don't have them. Why are you asking about it, does the book show a additional diode in that circuit on that engine?
