Lawn mower blade bolt broke off
I have a John Deere Z425 zero-turn mower. I was mowing today and the bolt holding one of the blades sheared off so half the bolt is still stuck in the threads. Any idea how I go about removing the rest of that bolt?
Thanks in advance!
Thanks in advance!
I would suggest that you try a product such as EZ Out Damaged Screw Extractor. Below is a link to it on Amazon.
https://www.amazon.com/Damaged-Extra...345-9759243?ie
If it's up in the hole, it's probably going to be more work to get it out than you want to exert. I would try a left hand drill bit and see if it even offers to turn while drilling. If not, it might be easier to just replace the jackshaft.
I've seen photos and videos of using a TIG welder to weld a nut onto an exposed bolt, and using a wrench to remove the bolt. On a bolt broken flush to the surface, another video showed using a TIG welder to build up metal high enough to grab using vice grips to remove the bolt- but you have to be careful not to weld the bolt permanently into place.
Absent a TIG welder, if the bolt is big enough the left-handed drill bit idea could hollow out the bolt enough to get an "e-z out" bolt extractor into place. Tap it in with a hammer and the left handed flutes catch the sides and hopefully allow you to remove the bolt with a wrench. This set is about $10.
Good luck with it, let us know how it goes!
I would be with cheese on this one. You could remove the shaft and try a repair, but they are usually cheap enough to replace and be done with it...albeit you do have that dirty JD name on it so
I'm speculating that the bolt broke off when the blade hit something really, really solid and so it is in there now just about as tight as it can be.
I hope you can remove the Spindle/Quill Assembly from the deck and work with the EZ Out on a bench . . . . or get a new blade mount for the Quill Assembly. Maybe fix this one at your leisure and then save it for a spare.
