Honda HRX 217 Lawnmower Pull Cord Stiff
Old 05-02-18, 04:10 PM
My Honda HRX 217 lawnmower pull cord is very stiff to pull. However, when I remove the plug, it pulls freely.
Prior to this problem, it seems to have worked well the last time I operated it.
I will appreciate any suggestions on how to fix it.
Thanks!
Old 05-02-18, 07:05 PM
Received 3 Votes on 3 Posts
When you spin the engine over without the plug in it does anything blow out of the plug hole?
Old 05-02-18, 07:50 PM
Received 373 Votes on 350 Posts
Welcome to the forums.
My sister's Honda looks just like that one.
Be sure to squeeze the blade engage handle before pulling the starter.
Old 05-09-18, 06:57 PM
Nothing comes out. I saw videos of people that solved the problem by expelling oil out through the plug opening, but that is not the problem here.
Old 05-10-18, 08:21 AM
Received 2 Votes on 2 Posts
Did you hit something solid that made the engine stop abruptly if so you could have a sheared or partially sheared flywheel key which can make it hard to pull the rope and it will kick back at times. Have a good one. Geo
