Compressor motor wiring
Old 05-04-18, 01:39 PM
Hi
Just purchased 5.5hp twin capicator motor can anybody help me which ones the 3 core mains lead conects to 240v uk
Old 05-04-18, 02:21 PM
Received 517 Votes on 487 Posts
Welcome to the forums from the UK.
Can you post a closeup picture of the wiring diagram sticker for us ?
Old 05-04-18, 03:27 PM
Wiring
Please find enclosed picture that you requested
Old 05-04-18, 03:31 PM
Sorry I havnt put the mains cable through yet it will go through that cromet.
Old 05-04-18, 03:34 PM
The wire in the pictures are from the capacitors no mains been instered yet they are the original connectors from manufacturer I haven't touch them
Old 05-04-18, 06:52 PM
cheese's Avatar
Received 22 Votes on 19 Posts
I think I see how to wire it, but which way do you want the shaft to turn (when looking at the end of the shaft, clockwise or not)?
Old 05-04-18, 07:07 PM
The arrow is pointing anticlockwise when in relation to the shaft
Old 05-04-18, 09:06 PM
Excellent picture.
Are the screw terminals labeled with those letters ?
Can't see any labels in the picture.
The power cord connects to U1 and U2 but the jumpers need to be set for CCW operation.
Old 05-05-18, 03:52 AM
Hi
does it matter about which lead goes to U1 & U2 the positive or neutral
Carl
Old 05-05-18, 10:33 AM
It doesn't really make a difference and the motor doesn't care.
Usually U1 is hot and U2 is neutral.
Hi
sorry I don't quite understand about the jumpers I bought this motor brand knew I thought it would have thought it was wired up correctly he told me it was straight forward swap just need power cable connecting.
carl
Old 05-05-18, 10:35 AM
Since the motor is reversible..... the shorting bars get changed based on direction of rotation.
Old 05-05-18, 10:55 AM
The motor tried to start and the rotation was right it only ran for a couple of seconds then stopped keeps blowing fuses was told it can run off 240v 13amp plug because
off the capacitors.
Old 05-05-18, 10:59 AM
No.... that is incorrect. It will need at least the motor rating plate and then some.
That means at least 30A for starting.
Old 05-05-18, 11:51 AM
Thanks I will get in touch on tuesday where i bought it from said it was a straight replacement for mine i had 3hp motor off a standard 13amp plug
Old 05-05-18, 12:12 PM
That motor is almost double the size of the one it's replacing.
Old 05-08-18, 02:55 AM
Rang him this morning said ring back after 10 said all our motors run off 13amp get a wiring diagram for me he said.
Old 05-08-18, 08:40 AM
Wiring diagram
Just found out trip switch missing on mine sending me one out just have to wait and see they are convinced it runs off 13amp
Old 05-08-18, 05:20 PM
That item in that picture is a circuit breaker. It will not help the motor run any better or at lower current draw. It's just there as an additional motor protector.
