Walk behind No electric start.
Old 05-07-18, 05:52 AM
pugsl's Avatar
Received 29 Votes on 27 Posts
Troy Bilt 12aga2bjo11 Mower starts and runs good with rope pull. Has electric start pne day nothing happens when start button pushed. No sound or anything, charged battery still nothing. Can't find wiring diagram to follow wiring.
Old 05-07-18, 05:59 AM
Received 315 Votes on 289 Posts
Have you checked to make sure all the cables are securely connected? Then I'd check the switch to make sure it's working.
Old 05-07-18, 07:23 AM
pugsl's Avatar
Been working on other things, Still haven't open switch. Hoping was a common problem to lead me in right direction.
Old 05-07-18, 08:41 AM
The wiring is usually simple enough that it's easier to trace things out on the machine than follow a wiring diagram. I would start at the battery and with a multi meter or voltage tester follow the power until it stops. It could be a bad switch, open connection, blown fuse or bad starter motor.
Old 05-07-18, 08:48 AM
Received 42 Votes on 37 Posts
Last one I worked on had an inline fuse in plain sight in the line running up to the switch.
Old 05-07-18, 10:55 AM
Received 511 Votes on 481 Posts
According to TroyBuillt..... that does use an inline 40A fuse.
