JD L110 Issue
JD L110 Issue
Having issues with my 12 yr old JD L110 with the Kohler Command engine. The tractor will start, run normally for approx. 5 secs, then shutdown. Once shutdown, I do not even get a click from turning the key. If I let the mower sit for a few minutes, the process repeats. I had the battery checked and it is good. I'm assuming something electrical?
Any suggestions would be much appreciated!
Sounds like a connection, either battery connection or ground most likely. Could also be a bad fuseholder.
