Murray riding mower will not move
Old 06-02-18, 06:38 PM
E
I was mowing and it stopped moving...No noise , just slowed down & stopped.....Not the belt this time....Belt is intact....Jacked it up and wheels turn freely in gear or out of gear....Rear wheel turns one way and other rear wheel turns opposite 10 HP model 30550x92D.....Any help is appreciated....
Old 06-02-18, 08:18 PM
Received 125 Upvotes on 110 Posts
Which belt?
Some have two belts, one for the deck and another to run the hydrolic pump.
The deck belt that runs the blades has nothing to do with the drive.
Old 06-02-18, 08:34 PM
E
Large deck belt ok, blade spins when engaged......Small drive belt intact,not broken.....
Old 06-02-18, 09:22 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Is the transmission pulley turning when you're trying to move?
Old 06-03-18, 10:21 AM
E
I jacked it up started it, put it in gear and i can't see the trans pulley moving at all......Wheels turn freely , one forward , one the opposite direction....How do i adjust the belt tension? I'll try to eliminate the easy stuff first...
Old 06-03-18, 01:06 PM
V
Received 2 Upvotes on 2 Posts
Does that one have an Idler Pulley on the Clutch ?
I have an 1973 AMF Rider (predecessor to Murray), which lost it's linkage to the Clutch when it was about 25 years old, and required a little welding to put it back in action.
Old 06-03-18, 11:25 PM
cheese's Avatar
If the pulley isn't turning, the belt is off most likely. I think you're missing something.
Old 06-04-18, 07:24 PM
E
I'll check underneath again, thanks for the reply.....
Old 06-08-18, 11:20 AM
E
Well i want to thank everyone that helped me.....The drive belt had slipped off the small middle pulley that engages , not the stack pulley and not the trans pulley....Don't know how this happened but it did.....I have broke around 4 belts over the years but never had one slip off...Glad it did ! .;;;Again thx to everyone hope i did not waste too much time....
