Riding Mower Lack of Power
I have a Simplicity Regent (2690437) riding lawnmower with a 20hp briggs intek v-twin engine. It is currently displaying a lack of power and the engine does not sound like it is running smoothly. In regards to the power, pressing on the accelerator pedal results in the mower moving forward more slowly than it used to. I'm not an expert in engine noises, but the engine is perhaps making a bit of a pinging or misfiring noise.
So far this season, I have changed the oil, changed the spark plugs, and replaced a worn drive belt. However, none of these seemed to make a difference on the lack of power. I did also confirm that both plugs are sparking, although i am not a great judge of how strong the spark is.
Are both cylinders firing?
When you replaced the spark plugs what did the old ones look like?
How do I know if both cylinders are firing?
The ends of both plugs were black and at least one of them looked to have some oil on it. I did decide to check the oil level at that time, and it was within the ideal zone.
In terms of the choke, I can confirm that opening and closing it does make a difference in engine operation, as I do have to adjust it every time that I do a cold start on the mower. Am I correct in assuming that this would be a good indicator that it is working properly?
Is the exhaust smoking? If so and with the oil covered spark plug I would put a blown head gasket on the list of potential causes.
Check for spark at both cylinders and if both have spark I would look for others signs you might have a blown head gasket. If that's it it's a pretty inexpensive repair.
I don't see where it was ever confirmed the engine was running on both cylinders, start it and remove one spark plug wire if the engine tempo changes/starts to miss then that cylinder is firing then try it on the other cylinder. Have a good one. Geo
Is there something that I should check with the head gasket next? I will say that I am not noticing a constant smoking like I saw in several videos that demonstrated symptoms of a failed head gasket.
Do some reading online. There are many different symptoms. Smoke, fowling spark plugs, oil on spark plugs, more than usual amount of oil blown up into air filter housing.
I don't recall you mentioning changing the air filter. Have you done that? A clogged air filter can rob power.
The air filter looks a little dusty, but not too bad by my eye. I fired up the mower, let it run for a minute, and then removed the air filter. It made no difference in terms of how the engine runs.
Someone that I know recommended doing a compression test. I did that earlier today and found that the left cylinder (as I sit in the driver seat) has 140psi. The right cylinder has 130psi. Does that sound reasonable for this type of engine? I don't think I previously mentioned this, so the engine number is 406577.
Those numbers are great. What color is the smoke? Have you checked the valves and their adjustments?
I double-checked again to be certain on the smoke item. When I first start the mower, there is a decently strong exhaust smell, but no smoke at this point. Perhaps this is pretty normal.
I have not looked at the valves. Do you have a recommended video or instructions for that?
I'd start by removing the valve covers and making sure the push rods and rocker arms are in palce and not loose.
This is another demonstration of my ignorance on this topic, but after investigating further, it turns out that the noise that I was hearing and thought was coming from the engine is actually coming from the transmission area. After doing some further research, I am looking into changing the transmission oil.
In addition, I have noticed that there is another belt that has the beginning of a tear in it. I'm planning on replacing it. The part number is 1728008 with a description of "V-BELT, Drive Belt, Aramid/Kevlar". I don't know if this is normal, but I also notice that it is quite loose.
Obviously, the noise from the transmission doesn't explain the oil that I saw on my spark plug earlier, but perhaps it is the source of the mower's reduced power.
You folks probably already know this, but maybe it will be helpful for someone else to read. The belt is the transmission drive belt. It appears that this is loose when the parking brake is on, but then tightens up when you release the parking brake.
When you say reduced power, that indicates the engine is not running properly. Is it the engine not running properly, or is the mower not going as fast as it was? The transmission belt could cause noise and loss of speed and pulling ability but not a loss of engine power. Just trying to clarify if it's an engine problem or not.
#21
The mower is not going as fast as it was.
Does anyone happen to know how to use a drill to purge a k46 transmission? I see some mentions of doing this on the input shaft, but have not seen any clear illustrations or videos showing where to find the input shaft.
#22
K46 means nothing to me?????????????
If it is a Hydro tranny the input shaft is the pulley that is driven by the drive belt. As for purging, lift and support the mower so the rear wheels are off the ground, pull the bypass lever that allows you to push the mower, then with the engine running engage the drive forward for 5 seconds, then reverse for 5 seconds. Repeat this 6 times. Now engage the bypass and repeat the above procedure.
#24
I am working on the transmission drive belt this evening. I got the pto off, but I'm not sure how to get the belt off of the engine drive pulley. There is a tab right next to it coming down from the frame. There is a key underneath the pulley that is keeping it from coming off. Take a look at the pic below. Any suggestions?
#26
That pulley should come off but might be stuck. A work around is to remove the 4 engine mounting bolts and slide the engine toward the firewall/steering console. This should give you enough room to change the belt.
Not really advisable to bend the tabs however tempting.
#27
Moving the engine enabled me to get the belt off the pulley. My last remaining challenge in getting it off is the steering wheel shaft. There is a small gear at the bottom. Is there a way to remove the gear? Do I need to unbolt the plate that the shaft passes through?
Steering gear
Steering gear
#28
The gear is made to the shaft. You have to remove the steering wheel and drop the shaft all the way out the bottom of the mower to get it out.
#30
Do you have any tips on removing the steering wheel? I have linked the parts diagram below. I already have 1-3 removed. I'm guessing that I need to get 5 (klipring) removed, but i'm not even sure how I would access it. The picture seems to show a notch on the back of the steering wheel, but mine does not have that. If I pull up on 4 (wheel), there is a slight gap between 4 and 16. I'm actually questioning if this diagram is exactly like this mower, as I think my steering column is held on by two notches instead of four screws.
Parts Diagram
Parts Diagram
#31
After looking at the diagrams further, I have realized that the piece held by two tabs is a different piece, so you can ignore that statement. This is the proper parts diagram, but the steering wheel does not have a visible notch.
#32
If you have 1-3 removed, the wheel pulls up off the shaft from there. The clip doesn't come off until after the steering wheel is off. Sometimes they are stuck, you may have to bump it upwards to knock it loose.
#33
I'm going to suggest another rabbit trail to go down in regards to the loss of power...
I think it's a fuel system problem. I would remove the bowl on the bottom of the carb and clean it out. (It should be held on by a bolt that goes up thru the bowl). I would spray carb cleaner in the carb as the engine is running. Add a can of SeaFoam or other fuel cleaner to your gas tank and run it thru the engine. Check the fuel filter to see if it is clogged.
I have a walk behind mower that had a loss of power and the easiest thing was to replace the carb. $13 for a new carb! Can you believe that? $13! And on a Honda mower. Fixed it right up.
Good luck!
Good luck!
#34
Thanks, guys.
Cheese - Does it truly come straight up? I read something about a splined steering shaft in another forum post. I didn't know if there was a special trick. I admit that I am a bit of a weakling, so that is probably in play. If I continue not having any luck, would it be useful to try a puller?
#36
I got most of my mower back together only to find that I cannot get the new belt to slide back over the top of the transmission pulley. The original one came off by hand with ease. I expected it to be slightly looser due to the start of a tear, but not that much looser. I am leaning toward thinking that the new belt I ordered is truly not the right size. I did compare it with the other one before putting it on and it did seem slightly shorter. What do you folks think? The new belt is not an original oem part.
#39
Where would you recommend obtaining the belt? What is the length supposed to be (94 I guess)? Where did you find the length? I find it somewhat annoying that the parts catalog does not list the length.
