Excellent VR2500 pressure washer
Hi All, very Minimual pressure no matter how I try and adjust the unloaded, with water supply connected no HP hose I get a stream about 15’ with motor running a bit better but not much, with HP hose connected water bubbles out of the end, different hose makes no difference, I removed the Unloader and it moves in and out by using the adjustment on the end, I also removed the HP out fitting and in the bottom of that port there is a white plastic piece with a star shaped brass washer, see pic, is that supposed to be removable? DeVilbiss A01703 955413
Geo
Geo
If this your first time using this machine?
How long did you run it while holding the trigger on the gun?
I have three pressure washers and each takes a different amount of time to purge out all the air and get a good solid prime. One can go several minutes with weak pressure. Then as it sprays more I get a spurt of good pressure and the more you spray the more power spurts until a minute or two later it's all strong.
