How do I drain the oil from this riding mower?
Old 06-28-18, 06:42 PM
A
Received 2 Upvotes on 2 Posts
Notice how the drain plug sits low and several inches back from the frame. Seems that's either a huge oversight or there's a trick I'm missing (or both I suppose!). Can I get specific insight?
Old 06-28-18, 09:22 PM
cheese's Avatar
Received 110 Upvotes on 100 Posts
Is there a drain on the opposite side? If not, you can buy a socket to fit that head, or get a liquivac. I used a liquivac for pretty much every small engine oil change I do. Much less hassle, time, and no mess.
Old 06-28-18, 09:27 PM
XSleeper's Avatar
Received 1,700 Upvotes on 1,524 Posts
You can also put an extension on it.
Old 06-28-18, 09:58 PM
XSleeper's Avatar
Or park on a side hill and get creative with an aluminum pie pan... Cut it into a pizza slice sized pan with upturned edges.
Then once the oil has drained... put on that extension tube for the next time.
Old 06-29-18, 03:07 AM
V
Double check the bottom of the crankcase for another drain plug below . . . . what kind of engine is it ?
Old 06-29-18, 03:29 AM
Norm201's Avatar
Received 663 Upvotes on 586 Posts
This is perhaps the easiest solution. That is what I've done on my snowblower.
Old 06-29-18, 08:44 AM
A
It's a Briggs and Stratton 42A707
Old 06-29-18, 12:00 PM
Marq1's Avatar
Received 1,098 Upvotes on 998 Posts
As XSleeper stated, tilt the mower up and cut a piece of cardboard to fit under the engine so it drains right into a pan,
I have two mowers very similar and it takes 5 minuets and an empty cereal box!
Old 06-29-18, 02:00 PM
Norm201's Avatar
What Xsplr and Marq say is true but if you put on a pipe nipple with cap and just ride the mower up an incline on the opposite side you don't need foil or cardboard or anything. Just put a tin can or lower profile bucket at the end of the pipe nipple.
Old 06-29-18, 02:16 PM
A
With some offline help, I found out it was on the other side of the block...clean off, remove the cap, twist slightly to the left and pull out on the spout. Simple.
Do not see an oil filter anywhere on this engine however.
Old 06-29-18, 02:26 PM
Norm201's Avatar
Well that explains a lot. Is this a riding mower or a walk behind? If it's a rider it most certainly has a filter.
oops, your title says rider. You should have an oil filter.
Old 06-29-18, 02:34 PM
C
Received 282 Upvotes on 232 Posts
That plastic cap covers a valve. You can remove the cap, slide a piece of hose over the fitting and pull on the end of the fitting to open the valve. Mine has a couple of tabs that have to be depressed to allow the fitting to extend.
Old 06-29-18, 10:34 PM
cheese's Avatar
No oil filter on most of these. I did ask if there was one on the other side
Old 06-30-18, 03:12 AM
A
Yeah, I don't see an oil filter anywhere.
